samth3mancgp
I'm thinking about taking a leap forward and going HD. Here is my idea:
I want to start off with just one 96 I/O because I have no Idea how the inputs and outputs work on the 192 I/O with those crazy connectors that look like parallel printer ports! How am I supposed to get my XLR cable into that thing!?
I hear that the 96 I/O has a bad rep as being a slight step down from a 192, but how much worse could it be?! Is it going to be a step up from an M-Audio Project Mix I/O, or even the interface I was planning on replacing it with; the Steinberg MR816x? I can't imagine it would be a BAD sounding interface considering the price!
I will also be getting one of the older PCI-x process cards to start off. I'm running Windows so I wil still be able to use the older cards with my motherboard I think. Having extra power from the DSP will be relaly nice to have as well!! It's another big reason for me thinking of going HD.
I will be picking up the PT 9 HD crossgrade by using the hardware serial # on the 96 I/O when it arrives.
I think that if I play my cards right (no pun intended
) I can get started with HD and have all the benefits of DSP, while also upgrading to a much nicer interface than my Pmix for under $2000, and maybe under $1500 If I'm lucky! Are there any un-foreseen drawbacks that I should consider? What do ya think?
