L
Lale
Hi!
Few years ago I got LDC multi-pattern Fame tube mic off from a net auction. Mic is Fame SKEA002/W and I haven't been able to find any useful info about it. Soundking has been selling this mic at some point also. Mic is discontinued and was originally cheapish (apprx 400€) mic. I paid 80€ (!) for it and thought that I give it a go and see how it is. Case seems sturdy and build quality is suprisingly good. But soundwise the mic isn't anything special, it lacks detail, sounds "lazy" and is somewhat noisy. I tried swapping tubes, stock tube had really harsh highs, and I ended up using a GE JAN 6072A. I really couldn't get rid of the noise by tube swapping and the sound of the mic itself is still a bit dull and not interesting. It's somewhat decent, but I never end up using it. I try it every now and then but in the end it goes back to the closet and stays there.
Here you can see the pics of the mic:
http://www.bror.fi/tubemic/
I can provide more detailed pictures if you wish to see, just ask.
I'm not really skilled to see what type of tube mic this is, if someone could tell me somehing about it, i would appreciate it.
I'm also interested in trying to mod the mic to see if there was some potential. I have skills to do soldering well and basics of electronics, been building stompboxes and amps etc. Could you be able to point me the most potential procedures of modding this particular mic? Upgrading transformer? Capsule? PSU? Individual components? Should I just dump the whole innards and rebuild it from the scratch?
EDIT: almost forgot to mention, grille is build with two layers of mesh, outer is very typical thicker mesh and inside theres a second layer of denser mesh with thinner wire. No any foam of fabric used.
Any info is appreciated, thanks a lot in advance.
- Lale
- Lale
