RedStone
Active member
It doesn't really sound like digital popping. Try running your guitar straght into your soundcard (make sure to turn the recording level down). Or just try to eliminate as much pre-computer hardware as possible. If you dont have the adapters to do that (1 a high impedance xlr to 1/4 inch), check your cables ... I suspect that either a bad cable, or a bad connection somewhere has been causing you this grief. Try using a different mic as well ... even if the sound quality sucks, just in case it is the mic itself.
