			antispatula
Active member
I need to be able to run a mic into an unbalanced TS input. To do that I can simply solder the cold signal to the ground wire, and as long as the cable isnt long, there is no problem, correct?
			since ocnor isn't feeling gregarious right now I'll expound.
You need to convert the low impedance of the mic into a higher impedance that an unbalanced in can handle.
			I'm with ya' man!Thanks Bob I'm a little drowsy and didn't feel like trying to explain as it would require too much thinking.
			in it's simplest form a mic preamp in a mixer is often nothing more than an impedance matching transformer.Impedance isn"t really going to be the Issue as there is No problem running a Low impedance signal into a high impedance input (high impedance signal into a low impedance input would be a Big Problem) accept that it would be a Bit noisyer but all high inpedance inputs are going to be noisyer, The problem is going to be that generally a Unballanced input is not going to be a Mic Preamp input but a Line amp input which will not have nearly enough gain to get the mic signal to a useable level , typical mic preamps are going to have 10,000x Gain were a Line amp input could be anywhere from Unity gain to 10x gain....... Pluss an unballanced input is going to have no common mode rejection and is going to be quite noisey with a Mic.....
To fix this get a mic preamp and plug the output into the Unballanced input
Cheers
			yep2. So to plug a mic into the unbalanced input (ch2) I simply need to run it though a preamp, then into the input of the mbox?
			It should. Typically an unbalanced input is looking for a line level signal.and it would sound fine?
