Ok
I accidently left an exciter on the last mix on all the frequencies. Also you're right the limiter was slamming pretty hard. Here are some of the things I changed from the last one..
- Listened to the mix with nothing on the 2 buss, found the kick was quite loud, I had to adjust the bass accordingly, I imagine the exciter and limter where getting triggered by this and hence some sustain was carrying on the low/mids and that's what your missing.
- I also pulled a very slight amount of low mids out. Pulled down the snare 1 db and vox up 1db with less reverb to put them up front
A few questions
- are the vox too hot now or are you used to listening to the old mix? Are you becoming biased to one mix because you've heard it first? I've done this many times
- how much can a mastering engineer change as far as vox levels?
- Is this mix balanced enough to master or will he have problems with it?
