please help you smart people
  • Thread starter Thread starter musicsdarkangel
M
musicsdarkangel
I'm in n-track, i select clicktrack in the n-track metranome thingy, and test it. It says error opening midi-out device. I have a delta 66 (omni studio package) soundcard, and I just can't get the click track to work, and I can't really do it in logic audio either.
I can do it in cubase, but it's an audio click. Is there a way to get an audio click in n-track.
Is there a way I can fix this problem? It's sorta pissin me off, I have the latest driver, and I tried reconfiguring the midi garbage in n-track's preferences, but I only have one choice.
If they only do a midi click, as is the case in Logic, and you don't have a midi device to play it then your screwed. You need a softsynth, soundcard with midi synth or a good old fashioned hardware synth.
A quick way around this is to import a single 'click' wav file. You can use any type of percussive sample. Then just repeat paste it for every 1/4 or 1/8 note. Whenever you change the the tempo in the song it will change the spacing of the clicks accordingly. I have an audible click saved in my Logic template so it is always there when I start.
I am having the same problem with mine. I run all audio using a Delta 1010, but for MIDI it's gotta be Sound Blaster(I don't wanna give up soundfonts). Anywho, I havn't gotten it to work quite right with Win 2k yet, so I just use the PC speaker option for the n-Track metronome.
1... 2... 3... 4... 5... 6... 7... 8... 9...
. . . . . . . please don't double post. Thank you for your consideration.
is there a cheap program or soundcard or something I can get to help fix this problem?
