N
NotPaul
Hi All,
I'm new here and have a simple question. I just bought a dbx 266xl compressor and a dbx 586 preamp, both on ebay. (Both a dual channel units) I'm using ProTools with an Mbox2 and want to add these components.
I come from a long line of techincally challenged people ... A good friend reccomended that I buy insert cables to connect the two. The compressor has a sidechain jack, so I plugged in the single cable of the insert there, and the send and receives into the pre. (I followed the docs I found onlline, so the tip and rings should be in the right jacks; alternatively, I've switched them around to double check).
I then plugged the outs of the pre into the ins of the MBox, using TRS cables.
So, here's the problem. I plugged my bass into the I of the pore and got signal -- everything worked -- gains, meter, EQ. ALso, the compressor lights were working, although I couldn't hear anythinig from the compressor. This preamp has an INsert switch, which I think is supposed add the compressor signal. However, when I depress it, I get nothing. No sound, no signal, no meters.
I've never used sidechain before; I thought this was supposed to work like an effect loop on an amp (and I think I could easily hook the units up through their I/Os).
Any help would really be appreciated.
Many thanks in advance.
Andy
Andy
