Please audio guru's help...
  • Thread starter Thread starter Tusk
T
Tusk
I'm just trying on my new Daw the great plug-in "Amplitube" from Ik Multimedia
... but when i use it on my Cubase Sx track like an
insert effect and i load the default parameters of amps.. my Pc after few
change Freeze!! This happened only with this plug-in i've already test with others.
Ok I know that's this is my personal problem because i've test with another pc
less Powerful(sigh!)and it's works very very well!!
I'm really interested to use this plug-in 'cause i'm a guitarist.... Any suggestion?
This may be helpful my daw is configured (after hard work and research) just
as follow:
Hardware:
- P4 2,53Ghz Northwood
- Mo-bo Asus P4PE GBL chipset intel 845Pe(with his soundcard onboard disabled in bios)
- M-audio Audiophile 2496 Soundcard
- Matrox G550 dual head videocard
- Hd1(o.s and progr.): WesternDigital 40Gb 7200 8mb cache
- Hd2(audio project) : WesternDigital 80Gb 7200 8mb cache
- 1Gb corsair memory pc 2700 DDR333
Software:
- Win Xp Sp 1
- CubaseSX 1.0.5.58
- Reason 2.0.1
Thanx very much for your support i'll appreciate your reply soon.
Tusk.
perhaps some tweaking is needed
try this
www.musicxp.net
also see if you can get an earlier update of SX
i was using update 1.03 up until this morning, i'm back on update 1.02 after a series of midi annoyances
i'll let the gurus hook you up now
