C
cemk
Hey guys,
I'm going to be buying a Keystation (61es or 88es, depending on availability) and use it with my 27" iMac w/ 8GB RAM and 2.93GHz i7 processor with some piano VST's. I might also buy some other VST's later, but the main reason is piano.
Anyway. The iMac is not a music production device, since I'm no musician myself. (I'm a web developer and a UX designer, which probably translates to "geek" somewhere in the world.) But I know that it's got enough juice to run a piano VST without a need for any extra equipment.
On the other hand, I'm in love with the new 11.6" MacBook Air, and I want to buy one as my portable computer, since iMac has more than enough power for the stuff I do, and I don't want to carry 2 kilos (a.k.a. "The MacBook I've got") in my backpack when I go outside. My question is: Would it be possible to use the MacBook Air the same way I would use the iMac, using GarageBand and a VST to play when I'm not at home?
I'm willing to buy a USB audio interface if that's needed. Either M-Audio's Fast Track or Steinberg's CI1/CI2. Or something else, in that price range. Whatever works.
I have to admit that I know almost nothing about the USB audio interfaces and what the VST's rely on (Processor power? RAM? The audio interface?) and the more I research, the more I got confused. I'll appreciate any kind of feedback you guys can provide.
Thanks in advance.
PS: For whatever it's worth, I did an Xbench test for the diskdrive and the CPU between the 128GB 1.4GHz C2D version of the Air and my 2TB 2.93GHz i7 iMac —the difference is a mere 3 points. (122 vs. 125) [My aluminum MacBook with 500GB drive and 2.4GHz Core 2 Duo processor, on the other hand, got only 75 from the same test.]
Thanks in advance.
