Played with midi, but how do I get it to wav?
  • Thread starter Thread starter sjaguar13
sjaguar13
I played around with Cakewalk making a few drum tracks. I then figured I should try the guitar tracks to see how the sound together (I just made them up and couldn't play them as fast as I wanted to with the drums). I was going to show the final version to a couple of people, but I wanted it on a CD. My question is, how do I get the midi file or wrk file to a wav?
These are the steps for re-recording any MIDI tracks that are using your sound card's internal synthesizer sounds – such as FM, wave table or SoundFonts:
- Open the file you're working with.
- Arm one open track with a Source of Stereo, or two open tracks for recording audio by setting the Source column to Left and Right. If you have more than one sound card installed, make sure you select the Source of the sound card that is playing your internal MIDI sounds. Also make sure that you don't have any tracks set with a Source of MIDI in Cakewalk, or you could overwrite them by accident.
- Next, open your sound card's mixer device. This is normally done by choosing Start | Programs | Accessories | Multimedia | Volume Control | Options | Properties. Click on Adjust Volume For Recording, and make sure all boxes below are checked. Click OK, and locate the slider marked MIDI, Synth, Mixed Input, or What You Hear. Check the Select box at the bottom, then close the window.
NOTE: Some sound cards, such as the SoundBlaster Live, have their own proprietary mixer. If yours has one, please use it instead.
- Press Record, and all of your MIDI tracks assigned to the card's internal synthesizer will be recorded as an audio track (or tracks). After you are done recording, mute the original MIDI tracks. This will save confusion, since you'll be listening to them as audio tracks now.
Here's how to re-record any MIDI tracks that are played on your external sound modules or instruments:
- Connect the audio outputs of your MIDI instruments to the line inputs of your sound card.
- Open the file you're working with, and arm one open track with a Source of Stereo, or two open tracks for recording audio by setting the Source column to Left and Right. If you have more than one sound card installed, make sure you select the Source of the sound card that is playing your internal MIDI sounds. Also make sure that you don't have any tracks set with a Source of MIDI in Cakewalk, or you could overwrite them by accident.
- Next, open your sound card's mixer device. Choose Start | Programs | Accessories | Multimedia | Volume Control | Options | Properties. Click on Adjust Volume For Recording, and make sure all boxes below are checked. Click OK, and locate the Line In slider. Check the Select box at the bottom, then close the window. To make sure you're recording at a good level, you'll need to check Cakewalk's audio meters in the Console View.
Press Record, and all of your MIDI tracks assigned to the external MIDI instrument will be recorded as an audio track (or tracks). To save confusion, you should mute the original MIDI tracks, since you'll be listening to them as audio tracks now.
Once you have all your tracks as audio now it is matter of exporting them to a file.
To create the file in Cakewalk 9.0, solo the new audio track(s), choose Tools | Mixdown Audio | Export to File, and select the file type you wish to create.
In Home Studio 8.0 and earlier, which does not include the Mixdown Audio feature, simply select all audio tracks in the file and choose Tools | Export Audio and choose the file type you wish to create.
I am not sure which version of cakewalk you are using but this should set you on the right track. If you need more help check out this link
Hope this helps!
Vice
Ok, now I got a wav file, but the tempo is slower than the midi file. As soon as it goes into the second bar, it slows down....why?
You´re in troubles...it can be your RAM,the cpu speed,the soundboard,....you will have to detail your sistem first,so i can advise where the problem mite be..
xxeerrs!
I set the tempo higher, so when it slows down it's at a speed fairly close to what it should be. Anyway, here's my sucky Compaq system:
Pentium III 550 Mhz
ESS Allegro Sound Card (I'm pretty sure this is onboard audio)
Intel graphics card
140gb hard drives (2 - 30 gigs and an external 80 gig)
128mb of PC133 RAM
Windows 98 SE
Did I miss anything important?
