K
kher
I have an audio recording done with Sound Forge 7.0 and saved it in SOund Forge Project File. I have burned the CD, but I can't play it on a regular CD player? What need to be done?
You burned the data file to a cd, most likely. You have to save it as a .wav file first, and burn that to cd.kher said:I have an audio recording done with Sound Forge 7.0 and saved it in SOund Forge Project File. I have burned the CD, but I can't play it on a regular CD player? What need to be done?![]()
kher said:The source is 44.1khz/24bit and I burned it using Sound Forge's Burn Track-at-Once Audio CD.
Use a different program and make sure the file is 16 bit, 44.1khz.thane1200 said:I think that is the problem, the exact same thing happened to me when I tried a "Direct Burn" from the same program. I would use another burning program.
It can be played on normal cd players if you finalize the session and close the cd. You should have those options in the program you burned it with. If not, you need to look at Nero or one of the other cd burner programs they have out there.kher said:Since my CD can only be played on the computer using RealPlayer, Window Media Player and iTunes, what is the correct way of stating it on the CD sleeve. Is it "This CD can only be played in RealPlayer, Window Media Player and iTunes format"
Roxio also has these options, I think you may need to open "advanced options" or "more options" in the window that opens just prior to burning....Rokket said:If not, you need to look at Nero or one of the other cd burner programs they have out there.
Yeah, I've got Easy CD and DVD creator 6. Version 7 is supposedly better, but it's more for DVD than CD...cellardweller said:Roxio also has these options, I think you may need to open "advanced options" or "more options" in the window that opens just prior to burning....
Rokket said:Yeah, I've got Easy CD and DVD creator 6. Version 7 is supposedly better, but it's more for DVD than CD...
