Playback pedals?
  • Thread starter Thread starter tom18222
T
tom18222
yes
Are there any harddrive based pedals that playback sounds your record for live situations, like if i have a syth pary in a song, i puch on the pedal?
i need it HD based so i can load it from my PC
What you need is a sampler with MIDI input so you can use a MIDI foot controller (like the Behringer FCB-1010) to trigger the samples. You might want to ask over in the Keyboards and Sound Modules forum, as this question really doesn't have anything to do with guitars.
Check out the DigiTech JamMan. Stock it will hold 28 minutes of CD quality (44.1 khz, 16 bit, mono) clips. With additional memory you can expand that to 6.5 HOURS. It has a USB interface so it can be loaded from a PC.
There is an optional 3 button footswitch that will allow you to select which clip to play without touching the controls on the box. Easy to use and sounds very nice.
Don
