Picking up Radio when my vocal mic is on??
  • Thread starter Thread starter jamit
J
jamit
When I have my vocal mic on I can a radio station in my headphones it is a MXL 990 mic I cant take it I need help
AM or FM?
You most likely have a loose connection somewhere in your signal chain which you'll need to isolate. It may or may not be your microphone.
Do you have other mics you can try, other leads etc.
My old Fender Dual Showman used to pick up a station too...weird.
On the OTHER hand, you can always listen to a radio station now when your bored.
AM or FM?
Bad cord. That's my vote because the same thing happened to me last Saturday. My trusty guitar cord must be getting loose so I switched to a new TRS cable and problem solved.
It's all about shielding. You mentioned hearing the radio station in your headphones. You ned to isolate what piece of equipment is picking up the signal - changing one piece of equipment at a time should help do that. Try a different set of headphones first (or use speakers). Then a different mic (same cable), etc.
It could be the voices in your head... just putting that out there.
No, it's most likely the shielding in your cables. I've had problems with it when i played electric guitar. I'm a fan of monster cables, i've never had anything go wrong with them... although they do usually end up lost or stolen.
