Philip Rees TS1 Tape Sync Unit
  • Thread starter Thread starter diskobox
D
diskobox
will this allow me to sync a DAW with a Tascam TSR-8 Reel to reel with the DAW as slave?
Yes, it will.
You would record SMPTE onto the TSR-8, and have the TS1 convert that into MTC for your DAW to chase.
I've done this using Cool Edit Pro 2.0, but you'd have to check your software, and it's ability to chase MTC.
-MD
Most DAW software these days support sync to SMPTE or MTC. Use the highest frame rate supported by both, and never split a stereo pair between tape and DAW. Also, chasing the clock will put an extra load on your computer, which could be a problem with a slower computer if you're also asking it to run a boat load of tracks and plugins. Otherwise, I've had pretty good results using MTC sync. It's not sample accurate, but it's close enough in most situations. Of course you lose one of my favorite things about DAWs; instant locates, rewinds, and loops. But sometimes I do miss the sound of tape.
