brassplyer
Several times I've successfully peeled the track away from a vocal by lining up their recording with the original backing track then phase inverting just the backing track. It's even worked if their recording was a mono mixdown leaving just a trace of the backing track portion of their recording. Why I would do this is re-mixing a recording where there's an issue and don't have access to the isolated vocal otherwise.
I find some really obvious peak that stands out in both - the waveform generally isn't absolutely identical but close enough where the peak is clearly defined. Then zoom in tight and adjust one track back and forth sample by sample to get them as closely lined up as possible and find the spot and volume balance between the tracks where the backing track becomes the least audible.
However I tried this using Cakewalk by Bandlab and I can't get it to work. Any theories as to why this might be?
