NashBackslash
Hello. I have a very big problem here, and I hope someone here might be able to help me solve it.
All this while, my DAW setup is a single, 120GB hard drive, partitioned into 2 drives; one for system, the other for audio data. It's a Seagate hard drive.
After doing a lot of reading on the internet, most people recommend a second physical hard drive.
I shopped around to find an inexpensive hard drive that I'd add as a system disk. I went for a 40GB Western Digital hard drive.
I put the Western Digital hard drive into the primary IDE, and the Seagate hard drive as slave. Since the Western Digital HD is empty, I did a NTFS quick format on it, and a fresh install of WinXP on it. Everything went fine.
And then usual things to do upon a fresh installation: install latest video drivers, audio interface drivers, install DAW, install plugs, etc. No problem there. In fact, the whole process took about an hour and half, and in that time, I managed to setup an exact duplicate of my DAW setup which was installed on the Seagate.
So what did I really want to do? I wanted the new 40GB to house the system files. I wanted the 120GB to be the new audio only disk. Since there were 2 partitions on the 120GB, I planned to make it back into 1.
To cut a long story short, I backed up all my audio data, deleted the partitions, and formatted the 120GB using quick format NTFS. I then transferred back the audio files back into the 120GB.
I thought my work was done. So I went away for a while to rest because I was pretty tired doing all that setup job. Then the horror happened.
I came back, ready to mix. I opened a particular song which used up about 10 tracks. Very minimum usage of plugs. So I clicked play just to listen to it.
I notice that the Sonar meters are moving very, VERY slowly. Every now and then it would pause, like as if it was choking. TEH HORROR!!1 I opened all my other projects to see if it was a problem with that particular song. No good - ALL of them slowed down like HELL. There was even this one song which used up about 20 tracks with LOTS of plugs, and it used to not show even one bit of slowing down, now the meters look like they're moving at like 0.0005 FPS! It doesn't drop out, but I'm sure it will if I left it long enough!
It's weird because I have NEVER experienced pauses and slow downs before. Back then, the audio and system were actually sharing one physical HD (on two partitions, though).
I did have problems with the previous installation though:
A) MOTU drivers would randomly not load on Windows startup.
B) Tends to restart the PC ALL THE TIME. During tracking, mixing - it can happen any time. This is the most annoying problem ever. It does NOT slow down or pause though! Even with heavy usage of plug-ins.And almost never drops out. It just restarts itself.
C) The previous WinXP installation is somewhat buggy because back then I installed Windows using a dodgy CD-ROM drive. Has long been replaced.
These were some of the reasons I wanted to install a 2nd HD. But ironically, it just made things worse. A LOT worse. I can't finish my projects like this. I am so desperate, I need my system fixed ASAP because my clients aren't going to be happy if they hear me say "there's something wrong with my PC, so your mix isn't done yet". Please help... anyone... I feel like breaking down right now...
EDIT:
Oops, forgot my system specs.
Pentium 4 2.4 GHz
1024 MB RAM
VIA chipset motherboard
VIA chipset PCI firewire card
Eagle 3D 64MB video card (it's a copy of the GeForce cards)
Seagate 120GB hard drive
Western Digital 40 GB hard drive
MOTU 828 MKII audio interface
Cakewalk Sonar 3.1.1
1) I know VIA chipset suck, but I've had these in my PC since like, even way before I even did any recording. I didn't bother building a new PC rig back then so I just used whatever I have. I will probably change the firewire card soon though.
2) The video card sucks, but I don't use the PC for any graphics job. Like I said earlier, the meter display was fast and had no problems before I installed my 2nd HD. The video card certainly didn't have anything to do with it.
EDIT 2:
Both setups were on fresh installs of WinXP SP2 and no hotfixes (don't have internet at studio).
- Nash
EDIT:
Pentium 4 2.4 GHz
1024 MB RAM
EDIT 2:
- Nash
