Myriad_Rocker
What advantages does Firewire have over PCI?
What advantages does PCI have over Firewire?
What are the disadvantages of each?
Myriad_Rocker said:What advantages does Firewire have over PCI?
Myriad_Rocker said:I knew that about firewire.
So PCI is faster. That's what I thought but I wanted to make sure.
dgatwood said:PCI is also going away. The industry is midway through ditching PCI. Apple announced new machines Wednesday with PCI Express, which isn't compatible with PCI cards. Lots of PC vendors have PCIe hardware out there, too (some with PCI/PCI-X slots in addition, but not all).
Unless you're planning on keeping your current machine until after you replace your audio card, PCI is a bad idea.
bigwillz24 said:The PCI-X technology you speak is used in servers doesn't that mean it will be another 5 or 6 years before the technology is actually cheap enough for regular consumers?
chessrock said:Well, if the Firewire card has a significant enough amount of DSP actually built in to the card, as some of them do, then -- although I'm not 100% certain or knowlegable about this stuff -- but wouldn't the speed and track count capability go way up and the latency down significantly (since you're using the firewire interface's DSP rather than the computer's) ?
