D
dbrook2010
Hi,
I have a pair of KRK Rokit 5 G3 monitors and I'm wanting to get the best setup I can with the equipment I'm using.
I'm currently using an internal E-MU 1212m card, running balanced outputs to a Mackie Big Knob.
On the E-MU software, I have outputs set at +4dB, which I believe is correct for balanced outputs?
On the Mackie inputs, I have the +4dB button selected (the switch is either +4dB or -10dB) and the input dial is set to unity. The input dial on the DAW mix input ranges from -10dB to +10dB.
I've not yet connected the KRKs.
I have the PC volume on 100%. But, whilst I was testing this out yesterday, I noticed that the Mackie was showing some overs on the meter. In particular, with certain CDs or Ableton Live.
Why am I getting overs with only certain CDs or Ableton?
And my real question on this is, what's the best/correct way to reduce the signal? Should I turn down the PC volume OR should I adjust the input dial on the Mackie (which would put it under unity) ?
My next question relates to the KRKs. I'll be running balanced cables from the Mackie to the KRKs. But I'm not sure what to set the input trim/dial to on the back of the KRKs?
The default factory setting is +6dB, but I couldn't get from the user manual what I should set this to
Should I put this to around +4dB, unity, or leave it at the default +6dB?
Any help appreciated on this.
Thanks
Darren
Thanks
Darren
