B
brandmansam
What are the advantages/disadvantages of having passive/active monitors?
Which one should i choose for my home studio?
Here's a difference you may consider..Active monitors are great for sure ( well, some of them)..If the amp is well matched with the speaker, good.. As stated, they save one additional set up step.But my main reason for using passive monitors: If my amp goes down,I just stick in another one. If my speakers go down, I just stick in another pair..Unlike active. If either one goes down, you are SOL in either case unless you have another powered set laying around. Good luck..
There are actually THREE types of monitor:-
PASSIVE
These have a passive crossover and require an external amplifier.
POWERED
These are similar to the passive, but have the amplifier built into the loudspeaker. (NB: some people incorrectly call these "actives" - they are NOT).
ACTIVE
These have an active (electronic) crossover which then feeds separate amplifiers - one for each driver. With actives there is no passive crossover to soak up power and the full power of the amplifier drives each loudspeaker driver.
Personally I prefer actives.
I stand corrected.POWERED
but also mean that, if one part or the other goes, you lose everything.
Well yes . . . If the amp goes down replace it. If a speaker goes down, stick in another pair.
In either case, it is useful to have spares handy.
but at least that way I always have a backup in case something goes with the other set.
If your active / powered monitors die, it's a message from the gods to upgrade..
It's an interesting concept, having back ups of stuff. Where does one draw the line ? If the DAW goes kaboom ? Or the telly ? Or the computer ? Or the car ? Or the wife {And really, how often does that actually happen?
