HapiCmpur said:
Thanks for the swift reply, Mind Riot. I've already read Ethan's site, and I've also seen some of his videos at RealTraps.com. Although the link you gave me does show a diagram of a bass trap in the corner between two walls (as in Pathetic Sketch #3 below), it doesn't explain why that's an especially good placement. (I'm guessing that it's because it puts the traps at ear level?)
However, I've also seen many pictures of studios with traps mounted up in the corners between the walls and the ceiling, and I don't know why they're up there. (Take a look at the pics along the top of RealTraps.com's home page, for instance.) I also don't understand why foam traps belong in the trihedral corners but fiberglass traps belong in the dihedral corners.
I need some rules of thumb to help me determine the best placement for traps around my own little studio. It may also help people to know that I'll be recording and mixing in the same 12' by 14' room.
The reason why the fiberglass would be mounted up at the ceiling, forming the triangle with the walls is that all the bass frequencies that bounce around the room build up more in the corners, where three surfaces meet. Two surfaces are good (as in your sketch) but three are better. Fiberglass placed there will essentially 'trap more bass' so to speak. And if you neglect the corners and put treatment elsewhere it will pretty much be self defeating as the corners have the most bass buildup.
Whether foam or fiberglass, absorbing bass frequencies is best done in the corners of a room. Bass wavelengths are pretty long, and as you may know, sound travels by compressing and rarefacting air molecules. But when a bass frequency hits the wall, the air is not moving there at all. It takes a few inches (again depending on bass frequency) away from the walls after the wave bounces off for the air to start moving. To steal one of Ethan's illustrations, think of a pool ball that is banked off the side rail. It may be moving at a hundred miles an hour, but at the exact point where it strikes the rail, it's not moving at all. This is why you can't make bass traps out of thin material attached to all your walls.
One of the reasons putting them in the corners is so effective is that the fiberglass is effectively at varying distances from the wall. At the center of the fiberglass sheet, where it's directly opposite the corner, it may be more than two feet from the wall. But an inch from where it meets the wall, it may be only an inch or so away. This allows the fiberglass to absorb a range of frequencies, since many different frequencies' wavelengths will be within those distances.
As these waves are bouncing off all the surfaces in a room, naturally the most effective way to absorb them is to place your absorption (fiberglass or foam) where multiple surfaces meet. In a rectangular room that so many of us have, this is the corners at the floor and the ceiling.
Foam bass traps along the wall/ceiling juncture do work and can augment the bass trapping of a room, but the best place to START is the corners.
Put fiberglass four inches thick across as many corners of your room as you can, and that'll be a VERY good start. Not just on the floor, but on the ceiling too. You can build a simple frame for them to hang them, or make a cloth covering for them and hang them with hammer in grommets or whatever you can manage. This is by far the most cost effective way to do it, and it's way more effective than foam bass traps.
