pair of sdc's....
  • Thread starter Thread starter orksnork
O
orksnork
They look pretty cool, but I've never heard of them (Sterling Audio), or seen/heard them in the flesh. They list a 3/4" diaphragm (around 19mm), so I wouldn't call it a standard SDC... maybe a MDC. :)
I heard good things about the AT-2020, which has a diaphragm about the same size (16mm). They go for around the same price too, $99 each, which might be worth checking into.
http://www.musiciansfriend.com/prod...ragm-Cardioid-Condenser-Microphone?sku=270620
The MXL SDC's also have their supporters.
orksnork said:
that's an ldc....this is for the use of drum overheads
Well, actually, the Sterling mic you have linked to your inquirey is closer to a LDC than the AT-2020... Most LDC have 25mm diaphragms, most true SDC have 12mm diaphragms; the Sterling spec shows a 19mm diaphragm, the AT spec shows a 16mm diaphragm. I believe the MXL you're looking at has a 1/2" (12-13mm) diaphragm.
Actually the AT 2020 would not be considered a LDC. I have a pair of them and it would a Medium Diaphragm Condensor mic at best. They'd work great as overheads. IMO
$ .02
an often overlooked model that would be worth considering is audio technica atm 37 (or is it 35? one's a clip on.you want the non clip) i picked up a pair real cheap have used them for all kinds of stuff works real well in x-y ... and a-t's quality controll is good so even if you don t buy them "matched" they'll be pretty close...
I second the MSH-1A, especially if you are on a budget and need them Mainly for overheads, and for about $20 each you can"t beat them....
well as i said, i dont mind spending between 200-250 for them...
for 20 dollars they can't be beat...but for 250 can they??
if so...let me beat them
found a matched pair of SP c4s with
• Shock Mount Adapters
• Foam Windscreens
• Pair of Cardoid Heads
• Pair of Omni Heads
• Case
for 299 free shipping
Cool
• Foam Windscreens
• Case
Sounds like a great deal! Let us know how you like them - they've gotten great reviews.
