painting computer monitor...
  • Thread starter Thread starter thane1200
thane1200
thane1200
Medicated Member
Hello all.
I consider myself pretty handy when it comes to modifying things, but I'm unsure of this.
I just got ahold of another CRT monitor (Gateway EV700 17") to combine with my current one; so that I can have a dual monitor setup. My question is this: Can I pull the "shell" off and paint it black to match my other monitor? I've taken apart televisions before and if the construction is similar I don't think it will be too much of a problem. If anyone has done this please let me know. Any hints/tips would be helpful.
Thanx
I believe there are some components in the back of a monitor that could kill/maim/hurt you if they are not completely discharged.
I would use a matte paint and just mask off the screen and spray away. a couple of light coats. Don't try to get it in one. And of course, make sure it's unplugged. It probably won't match 100% but I'd try it.
You can remove the coweling from a CRT without too much problem. I wouldn't paint it while it is still on in any case. There are vents that the paint would get through and lessen the lifespan of your monitor.
Carl
This is true with any vaccuum tube style set, they can store a charge for upwards of a week once un-plugged. I am wondering if the "shell" or "coweling" can be removed easily and completely for painting.
Thanx for the responses.
I wouldn't do it. Monitor are pretty dangerous if you don't know what you're doing.
I would think it would be hard to match the color of the first monitor....
it's that kind of thinking that will make you a million bucks one day.... :)
Sand and use the new Krylon (spelling) paint made for painting plastic. Comes in a spray can. I would paint them both. Start on the back to get a feel for it.
It's like that company that says"we don't make the products, we make them better". :)
I like your thinking, I'm going for it!
