Output and Playback different (?)
  • Thread starter Thread starter jsc308
J
jsc308
Hi, I'm new here, and also new to computer recording. I use a Focusrite Saffire and Tracktion on my Macbook to record and headphones to monitor.
My DAW setup is fine and works but my question lies in why: when I play the keyboard (which is plugged into the Saffire box), the outputs sound very... how should I put it... dry, unscrisp, and not how it's supposed to sound as if when I plug my headphones directly into the keyboard which is how it's supposed to sound. When I record a track, the playback sounds perfectly good - it's just that when I'm recording and monitoring myself, I don't hear what I should be hearing in playback which is very strange. This has nothing to with volume or panning adjustments or computer sound. I don't know what I need to configure in setup to make playback and headphone output sound the same.
I'm not using midi currently, I'm just running a keyboard directly into the I/O box to my laptop via firewire using the built in sounds.
Try krv anyway and explain in detail. Doesnt hurt
Are you running the keyboard into the saffire in stereo? Then are you panning the tracks?
