D
David Morrell
Hi from a newcomer.
I'm running CW9 Pro on a Pentium 4 at 2.4GHz with 512MB of RAM under WInXP.
CW9 is behaving fine except when I try to insert some WAV format files.
Some 44.1kbps 16 bit files insert OK, while others produce an 'Out Of Memory' error.
I've made sure that the Audio option for the project is set up for 16 bits all round at 44.1 kpbs.
This occurs even on a brand new project, where the offending WAV is the only kid on the block.
I read somewhere that the WAV format was developed from AIFF by Microsoft and that it has been tweaked over time to become somewhat less than a true standard. Could this be the issue, and if so, what to do about it?
Or any other bright ideas?
