I agree.
This is a multispeed machine right? 7.5 and 15ips? There would be a voltage divider or something for the capstan oscillator and I'm wondering if something is screwey with current leakage in different transport modes, but I just can't figure that...I mean...the capstan servo doesn't typically care if you are in PLAY or REC mode...it just knows "go" and "stop"...or actually it just usually knows "go" and the pinch roller does the rest.
It is actually 3 speed 3.75, 7.5 and 15, there is an internal switch to choose between two sets of them, and then trimmers for the three. But you're right, I don't see sep speed adjustments for "REC" vs "PLAY" just the three speeds, the capstan should just go or not go.
So, let me get this straight...you tracked with the speed control on "internal" or whatever, and when you reproduce against the tone oscillator you can hear that the oscialltor output and the tone reproduced off tape are "out of tune" and you have to use the pitch control to get the reproduced tone to match the oscillator output??
Yeah, exactly. I could actually tell from listening (I'm that good
) that the pitch was off. So I monitored "source" on left and "tape" on right and could hear the difference, so I adjusted the pitch control down to "tune" the playback.
Yup. It's weird. The tape is Quantegy 031 white box, but Quantegy not Ampex, (AFAIK, it all came in a Quantegy box, but nothing is sealed with the white box stuff) so no sticky tape issue. This AM I just ran some tape through it on play to just let the motors work a little, on the assumption that maybe, just maybe, the capstan was sticking for some reason on record.
Now that I think of it, a song that I had recorded on that same reel to align a Dolby unit w/ the other Otari sounded like it was playing back slower. So maybe there is a problem wtih teh capstan motor or motor control. The thing is it didn't sound like it was drifting. The tone (20 seconds worth) was steady.
So tonight I think I'll just record a full tape of tone, and see if playback wavers at all.
