optically combining Motu 828 & Tascam FW 1884 outputs
  • Thread starter Thread starter yrgs
Y
yrgs
hello
i'm am trying to achieve 12 channels of analog mixing (on 2 lovely akai MG614's for those who might care)
i have a Motu 828 mk3 set up as my main audio interface - of which i use 6 outputs to the mixers, works fine
temporarily i'm able to use a Tascam FW 1884, which should offer me up to 8 more outputs through ADAT (i would only need six)
the tascam receives every track i send from my DAW just fine, but the problem is that it only outputs them as a stereo feed to channels 1 and 2
it seems impossible to feed any tracks from tascam's outputs 3 to 8 individually to my analog mixer
i connected these devices:
- optically using 2 cables - optical out to in, in to out
- with Firewire, the motu directly to my computer, with the tascam daisychained onto it (i don't mind using the tascam as a control surface, but i don't want to mix on it)
any help would be greatly appreciated, thank you
oops, already solved this myself!
i aggregated the motu and the tascam by using the Audio Midi Setup in MacOsX, thus creating a new audio controller
no need for optical connection in my case even!
