One more midi question
  • Thread starter Thread starter Cal D
C
Cal D
I have input a midi file into my multi track recorder. The problem is, how do I make the midi files part of the final mix down? I can't right click on them and make them part of the "mix down to file" feature.
Given that midi files are simply data, rather than real audio (wav type) sounds, how do I make them be part of a real music mixdown?
Is there a midi to wav converter that I need? How does CEP handle this?
Thanks
Cal D, I think you better check the answer in your thread on MIDI forum. And FYI, you don't have to post exactly same question in several forums. Pick one forum close to your subject, then start a new thread. Do not double post crossing forum... ;)
