scottboyher
Old cheapy acoustic into a Dobro? Has anyone tried to do this with any success. Maybe just raise the nut and bridge?
JR#97 said:I've done the raised thing and it works great. Dont' forget to use metal fingerpicks and a thumbpick to get that 'metallic' sound. A heavy slide is better than the kind you slip over your finger.
As far as LP's go, most people mod them after they get them, hot-rodding the pickups, things like that. I've only seen a few of them that were still configured the way they came out of the factory, and they don't sound like you think a Les Paul should sound. A friend of mine got a studio custom that sounded pretty good as is, but he wanted Slash's sound and hot-rodded it. I didn't like the tone after he got done, but he was happy, so I guess that's what counts.lpdeluxe said:This is the same problem you run into with Les Pauls: a lot of LPs don't sound the way we think an LP ought to sound. The only cure is to look until you find one. I played every Dobro that came through town to find mine...only took 3 years.
Thanks for the info, lp! I guess I'd be better off buying one than trying to convert my cheapo acoustic (it's kinda thin plywood anyhow). I've always loved their tone, and I've only gotten to play around with one once, many moons ago...lpdeluxe said:I assume you are responding to what I posted earlier. A "real" Dobro has a fairly thick plywood top, and the "well" I mentioned sometime ago is attached around the circumference of the hole in the top and is attached to the (plywood) back as well. The resonator's rim rests on the edge of the hole in the guitar, and the arms [or legs] of the spider (that supports the bridge) rests on the lip of the resonator. A machine screw goes from the center of the bridge saddles (there are two of them) into a threaded hole in the raised center of the resonator. The whole idea is that the amplification of the strings will be confined to the resonator and that the body of the guitar is as inert as possible (given the miserly construction of wood-body Dobros). I have attached a .jpg of the spider so you'll have an idea.
A biscuit bridge has a shallower resonator, and the bridge sits on a "biscuit" on the raised portion in the middle of the resonator. As always, it can be tricky to find a resonator that gives a particular guitar useable action.
There are pictures of Dobro parts in the stewmac.com online catalog, and there are various books (such as Tom Wheeler's "Guitar Book") that show the construction of Dobros. Dobros have bolt-on necks, but they resemble the banjo variety more than the Fender. There's no reason you can't use a set-neck guitar, though. The bolt-on feature was mostly to lower production costs.
One advantage of Dobros is that you can take them apart much like a Fender Strat, say, and trade out parts and put them back together. One caveat, as I mentioned before: everything MUST fit tightly, or your resonator will be resonating with rattles instead of with notes.
