G
gusfinley
So I noticed last week that the plates on the EL84's in my DSL401 were glowing. The tubes has been incorrectly set up (biased WAY hot) due to a miscalculation and the fact that the four tubes share the same bias setting.....
I kept putting in different tubes (spares) and finally found a set that wouldn't glow. So I bought a new set of JJ tubes and last night they were glowing too!!! I checked the bias setting and it was correct as per Marshall's recommendation.
At this point I am quite puzzled so I pulled out my multimeter and started poking around thinking that somehow something in the circuitry of the power tubes was messed up... It all looked Okay.....
Then I checked the plate voltages and found that they were at about 415V!!! Now, two weeks ago when I measured them they were at 396V. The voltage somehow increased by 20V in two weeks.
I couldn't figure it out, and then I decided to test the line voltage - it was at 123V AC - a few volts high.. Then I got thinking that the power transformer uses a windings ratio to step up the voltage and so that "few" volts translates to Many volts by the time the amp filters everything to DC.
This morning the line voltage was back to 120V or so, but I'm still getting about 409V on the plates. Luckily I have some equations that will tell me what kind of bias current to set for each voltage.
Looks like I might have to check it every once in a while to see what it should really be at.
Is this type of thing normal, or do you think my apartment just has really bad power?
