carlosguardia
I have a 1.6 GHZ PIV with 512MB RAM, 2 40GB HD at 7200 and record with Sonar. I'm using the SB Live Platinum 5.1 (duck for tomatoes... I know).
Here's my question, maybe the answer to it is very simple but here it is anyhow. Let's say I want to record some acoustic drums into my Computer. I set up the drums in my studio, try to obtain the sound I'm looking for and then place microphones where I believe they'll capture each part/piece of the set with accuracy; most likely it'll be a few SM-57's, SM-81's and a Bet52 for the kick. Ok, and say I use a total of 8 mics. Then I plug in every output of every cable of every mic into a "snake" that then takes the signals into my control room. Now that sounds like up to now everything is going to be alright but here's the question. The other end of the snake has 8 xlr male plugs (each one is numbered and each one is, as I said, representing the output of a mic that's strategically placed on the drum set). Now what do I do with these XLR male plugs in order to connect them to my PC??? I want to assign each mic to a different track in Sonar and I don't want to play around with the signal too much and don't want to lose impedance. I know that I'll most likely get a reply that'll read somewhere along the lines of "...dude, get a Delta 1010..." and that's cool, I've already started saving for that piece of hardware or something similar, but what I want to know is how is this going to work (how to set it up etc)? is this the ideal piece of hardware for what I want to do? how do I go about connecting the male XLR outs into 1/4" ins without losing impedance? Does the 1010 come with software that's compatible with Sonar and will I be able to record 8 simultaneous tracks with it?
Again, Much Thanks for your help,
Carlos
Carlos
