XTREEMMAK
Ok,
I'm still a little bit confused in regards to external mic pres. How exactly are the pres bypassed on "x" interface? From what I gather, there are multiple ways of doing this. I need someone to verify these to make sure they are right and if I'm missing something cause I still dont fully understand:
1. If "x" device has a channel insert, and your external pre can send/return a signal, then you can go via Mic -> Mic Pre In -> Send (TRS = Tip) -> Return on "x" device to bypass pre on "x".
2. If "x" device does not have a channel insert, then you can go via Mic -> Mic Pre In -> Line Out (Pre) -> Line In (Device "x") to bypass pre.
Number 2 I dont understand. Essentially, wouldn't you still be using the device "x" pre? Why or why not?
