Ok, am I nuts? A preamp Question
  • Thread starter Thread starter NL5
NL5
NL5
Unpossible!
Is it possible to get a decent sounding 2 channel tube pre with spdif and aes output for a decent price - even if it has to be used. I would like a little eq and a comp/limiter if possible as well.
Suggestions?
Thanks,
NL5
ps - I'm not shooting for the moon, just something workable.
What would you consider a "decent price?"
Forget the SPDIF / AES thing, too. Not happenin.'
I was hoping under $500 used. Why no spdif/AES...I have looked at many that had it. That way it would go straight to the recorder digitally. Although, my interface has a pretty good digital converter, so it's really not a neccesity.
Thanks.
NL5
edit - I searched the forums and found that the dbx pre's are not too highly rated, but for $500 new, I could get everything I wanted except. I was hoping there was something silmiliar only better sounding, that I could get used for the $500. The dbx's are going for about $35o used. I know that they don't compare to the high end stuff, but I can't afford a $2500 for a little "home studio".
Most of the el-cheapo tube mic pres pretty much suck (as in anything under $700 used).
You could spend the same kind of money on something solid state and wind up with a much better mic pre.
The RNP would be a good option in that general price range, for example.
All the SP/DIF/AES output means that the AD converter is in the preamp. If you say the AD in your interface/recorder is good, then don't worry about the digital out in the pre. I'm a big proponent of having a modular system so you can easily upgrade any part of your chain as funds allow. I currently have a Great River MP2 into a Delta 44. Now I can easily upgrade my converters and still have a great pre. Can't help you with tube pres as I do all folk/acoustic music and my MP2 works great for me. Good luck!
Don't have any experience with them, but the ART DPS is about $250, 2channel and has digital outs and a limiter system.
Well, for 500 hundred bucks you can either get a really crappy tube pre like an ART with digital outs that you don't really need, or you can get a pretty damn good solid state pre, the FMR RNP. You can forget about decent integrated eq and compression at this price range. You are better off just spending $175 on an FMR RNC for a decent separate compressor. Nobody is really making any outstanding affordable outboard eq at this time. The closest thing to a very nice affordable eq is 1 channel of Speck ASC for $500, or you could look for a used dbx, symetrix, or ashly unit. Until there is more affordable eq options available, most people on DAW systems seem to use plugins for eq.
The short answer is "no".
The longer answer is that it's pretty expensive to do tubes right. I know that there is a myriad of cheap boxes with little "glowy things" inside... but the fact of the matter is that the "toobs" were put in the box for marketing purposes more than for audio purposes.
As for A/D conversion... whew... there are so many things that need to go into a serious A/D converter that to do one with a reasonable tube front end would be out of most people's budget... and then to add compression/limiting? You're asking for the moon.
The real long answer is 2/3rds of a good book... a book I have absolutely no desire to write... but a couple of years of working and reading and learning and practicing and you'll start to get more of a handle on what is, and what ain't possible.
If I may suggest a path... work with the tools you have, borrow tools you'd like to try, get a feel for the path you'd like to adopt, then form a financial plan that will allow that plan's adoption. Yeah, it's going to take a whole hell of a lot longer to get somewhere, but at least you'll have a better idea of where you'd like to go.
The one thing I would suggest you avoid like the plague is the gear 'roulette' path... the path where you buy things, outgrow them, sell them for a loss, acquire other things, outgrow them, sell them at a loss and eventually move up to hardware that fits your style and sense of aesthetic. The best way to accumulate a collection of good working tools is to acquire good gear, one piece at a time, learn it's strengths and weaknesses then slowly add other gear to fill out the areas of weakness.
Most important in all of this is to remember that gear doesn't make music, people make music... concentrate more on forming your technique as an engineer than worrying about the hardware. A recording studio is an instrument that is in many ways as if not more complex than than the instruments recorded in a studio.
You should know not only about signal flow, microphone selection and placement technique, but also how to get the instruments you're recording to sound their absolute best before you record them. Just as you can't go down to a store, buy a Steve Vai model guitar come home and play like Steve Vai... you can't go to the store buy a bunch of recording hardware and be a recording engineer over night. It's going to take years of practice until you can play the instrument with any degree of competence... so start practicing and don't be in a hurry... and in a few years you'll be closer to where you want to be.
Best of luck with it.
well said...
