Offical Computer Specs. Thread!!
  • Thread starter Thread starter jaykeMURD
jaykeMURD
jaykeMURD
I sit on you.
I don't remeber if there was an old one, but here's a new one!
AMD Athlon 3700+ 939 Socket San Diego Core(OCed to 2.8gHz)
Asus A8N-SLI Deluxe Mobo (nForce4 chipset)
1GB Mushkin High-Performance DDR400 RAM (2x512)
Nvidia GeForce 6600GT PCIe 256MB
M-Audio Delta 1010LT
160 GB Hitachi HDD (UDMA)
250 GB Samsung HDD (SATA)
Rosewill TU-155 Black ATX Case
Zalman Fatal1ty 120mm CPU Fan
Aspire 500W ATX PSU
2x 80mm Arctic Cooling AF8 Intake Fans
1x 120mm Scythe Kama Bay exhaust fan
2x Blue Cold Cathode Lights
Windows XP Pro
Sonar 5 P.E.
Sony Soundforge 8
17" CRT Monitor
Microsoft Wireless Keyboard and Mouse
Nice Tripp-Lite Power Conditioner
I've added more ram so I guess I can post up again
Intel P4 3.0GHz
Asus P4P 800-e Deluxe
2 Gig Kingmax Turbo DDR 400
Matrox G450 dual display graphics
M-Audio Delta 1010
M-Audio Delta 410 (x 2)
Maxtor 160Gig SATA system drive
Maxtor 160 Gig SATA recording drive
Antec 4U 19" rackmount case
Antec 600w Silent PSU
Zalman flower cpu cooler
all fans by acousitfan
Windoze XP Pro
Cubase SX 2.0
Audobe Audition 1.5
AMD 3800+ X2
ASUS A8v deluxe
antec 550W TPII
40 gig OS drive
40 gig firewire drive
two 40 mirrored RAID backup drive
80 gig content SATA drive
6600GT 128MB video card
two 21" monitors
2 gigs RAM
EMU1820m audio interface
AMD Athlon 64 3800+
4 Gig Corsair RAM
ECS KN1 Extreme Mobo
2 150 Gig Maxtorl IDE drives, RAID 1(for work projects)
2 36.7 10,000 RPM WD Raptor SATA Drives(program files)
GE Force 6800 Dual DVI Graphics Card
ESI Juli@ Sound Card
Dell 24" Monitor, Widescreen, DVI, PnP..
Win XP Professional(audio tweaked)
Sequoia 8.0
Algorithmix Red linear phase eq
Algorithmix Renovator
Voxengo R8 Brain Professional SRC (stellar!)
Arctic Cooling Heatsink/Fan
two DVD R universal drives
two CDR Drives
100 Percent bought and paid for. Crack free baby. :D
Here my ghetto blaster:
Intel P4 2.4gHz
Intel 850 chipset mobo
1 gig RAM
2x Seagate Barracuda 80 gig HD
ATI Radeon 7500 (fanless! with TV tuner :D )
Steinberg VSL2020
2x UAD-1
Custom 4u rack case w/ sound absorbing vinyl-backed foam :)
2x blue LED fans
Zalman quiet PSU
MossCool copper heatsink (should arrive today!)
20" Samsung LCD :cool:
running XP Pro SP2 and Wavelab 5, going to 6 sometime later this year.
You wanna see a ghetto blaster? Check out MY specs ;) :cool:
PIII 600Mhz
256 MB PC-100
HP LightScribe DVD+/-RW
ATA-6 PCI drive controller
Rack-mount case
Echo Layla 3G
Cubase SX 1.x
Edit: 17" LCD monitor
Edit: 2gb system drive, 8gb & 60gb hard drives
It works for my uses :D
Jay
guts
PowerMac G5 Dual 2.5 GHz dual core (4 cores)
2.5GB RAM (2GB ECC, 512MB non-ECC factory parts)
500 GB SATA HD (about 50GB used)
250 GB SATA HD (240GB+ used, from my original machine)
NVIDIA GeForce 7800GT (256MB SDRAM)
Two ethernet ports
802.11b/g wireless
Bluetooth enabled
Liquid cooled w/ Zalman VGA cooler on video card... and located in the next room just to be certain. :D
Mac OS X v.10.4.3, I think (Tiger).
External Peripherals:
Bluetooth keyboard
Wireless (not bluetooth) trackball
Dual 15" LCD panels (2048 x 768 total resolution)
Presonus FirePod
M-Audio FW1814
Support:
Dual UPSes---one for the machine, one for the displays and peripherals. :D
Lemme see if I can remember my first DAW, c. 2000:
Intel P2 mobo, don't remember the chipset
Intel 200mHz P2
256MB RAM
Gateway mid-tower case
Yamaha DS2416 + AX44 breakout box (18 bit converters, woo-hoo!)
Minnetonka MxTrax for DSP Factory
stock video card
17" CRT
I think the total for that was around $3,500 :eek: although I had already had the PC for a couple of years by then. But hey, I could run 16 tracks with EQ and compression on every channel, and 2 effects sends with zero latency :cool:
The DAW was fed by a Peavey RQ200 and a Tascam Portastudio :cool: :cool: :o using Shure 57, 58, and 94s :)
dgatwood said:
Support:
I've got a 6 amp APC rackmount UPS/voltage regulator that runs my entire rack, including monitor and power amp :cool: I don't feel so ghetto anymore :D
