Slowjett
I got an Octava MKL-2500 today, and it had this stupid hum. Well most people talked about the cable haveing a bad sheilding connection to the mic. That cuased a BIG hum. I fixed that and the hum went down considerably.
Turns out the big Issue is the power supply. This is a chinese power supply, known to cause a real bugger of a hum. Basically rendering the mic unusable.
here is the culprit:
Its much smaller than the good russian power supply.
I opened up the chassis, and after prodding around inside the power supply a bit with a jumper wire I discovered the issue. It appeared the the mic cables were not grounded propperly at all. Look at my diagram.
Piont A is the ground from the wall plug. B is the common ground lead connected through the metal plate to point A, and then goes to the circut board. Point C is also a common ground, and it should all be on the same circut. When I touched C to A The hum went down considerably. So I figured I could just solder a wire from A to C.. Point B didnt give as good results as shorting A to B. Then I figured points A and B werent makeing good connection to each other OR the chasis.
So I took A and B apart and cleaned up all the contacting surfaces to ensure a good common ground over the whole unit. I used sand paper and cleaned up both sides of the plate around the AC converter where the holes were for the screws. Top and Bottom, down the bare metal. Then I cleaned the power supply chassis (houseing) around the screw holes.. Made sure to get right down to the bare metal there also.
I put the unit back together and to my amazment, no more hum! It was a very simple fix, didnt even have to fire up the soldering Iron.
Here are the before and after samples.
These samples should not be taken to show the clarity/quality of the mic, since it was in a noisy room and I was about 3 feet from the mic sitting at my desk. Any crackling you hear is me moving around in my chair. Plus I killed it with compression so you can hear it =]
Before
And After
Small samples of each next to each other...
Turns a not so usable mic, into a great mic.
Hope this helps you!
Josh
Before
And After
Josh
