Nuendo-Siena
  • Thread starter Thread starter Chinaski
C
Chinaski
Tengo un par de problemas con el Nuendo:
1- El primero es que me graba dessincronizado. Grabo una pista. OK. Luego escucho ésta grabando una segunda pista. Cuando escucho el resultado, la segunda pista está retrasada con la primera. Siempre sucede lo mismo y es muy molesto. Cada toma que hago la tengo que estar acomodando a mano.
2- en el Nuendo solo puedo visualizar 2 de las 8 entradas que tiene la tarjeta Siena. Cuando agrego un Track y voy a la consola en la parte superior del fader donde marca la entrada solo me da la opción de IN1 o IN2. Como hago para verlas todas?
Como se darán cuenta no soy ningún profesional del sonido, solo un músico de Uruguay tratando de grabar sus demos.
Athlon 1200M - 256Ram
Siena (Sek´d) 24/96 - 8in/8out analog
Desde ya muchas gracias!!
P.D: You can answer me in English.
Anyone who can translate this ??? I'm pretty sure I can answer the question as I've been using Nuendo for quite some time now ... but I don't understand Spanish
:( bizz
I'll translate it, but I need to hury to school right now... gimme a couple of hours :D
ok, here's the translation
I've got a couple of problems with Nuendo:
1. First one is that it records out of synchronization. I can record one track. Ok. Then I listen to it while recording a second one. When I listen to the result, the second track is delayed. Same thing happens all the time and it's anoying. I have to fix each take by hand.
2. I can only visualize 2 from the 8 inputs from the Siena sound card in Nuendo. When I add a track and then go to the console in the upper part of fader that marks the entrance, it only gives me the option IN1 or IN2. How can I see them all?
As you can see I am not a sound pro, just a musician from Uruguay trying to record his own demos.
In advance, thank you very much!
ok - Thanks goes to Pablo ;)
your sync problem is probably related to your drivers on the soundcard. I don't know the Siena sound card, but if you have ASIO drivers on it - use them. In Nuendo, under "Devices>Device set up>VST multitrack you can choose which drivers to use, under "expert" on the same page you can check the box "lower latency"
About the inputs : again - go to Devices>VST inputs - (or press F5)there you can enable the inputs you need
hope this helps
bizz
BIZZ: Thank you , I´ll try it and I´ll tell you tomorrow.
Problem 2 solved
BIZZ: The input problems is solved. Just what you said. Now i can see the 8 inputs. I´m working on the delay problem. I´ve got less delay but still is not good. I´m trying differents options ..........something about the buffer size???............or the ram box?...........i don´t know.......
Tomorrow i´ll tell you
Thank you very macho
P.D: Sorry about my english!!
Chinaski
C
Replies
2
Views
701
SPINSTERWUN
SPINSTERWUN
C
Replies
5
Views
977
Kryogh
K
