Ntrack Wont Record!
  • Thread starter Thread starter musicsdarkangel
M
musicsdarkangel
ntrack won't record for me, i use my project card. It used to record, but now it doesn't for some reason. ALl my outputs are fine, crud like that. But when i press record, it doesn't press the play button too and stuff, it just won't record. It sucks. Well, i don't have a volume control either. Anyone if anyone has any advice please tell. Thanx.
First make sure that n-Track is setup to use your soundcard. In File->Preferences->Wave Devices make sure to select your soundcard for input and output, and do a full duplex test just for good measure. n-Track has a strange way of resetting this every now and then.
Once that's done, open up the Recording VU Meter and make sure that your source is enabled. If you don't enable it, nothing will happen when you hit record.
Slackmaster 2000
Musicsdarkangel:
Personally, when I can't get something to work when it's supposed to work, I leave it for a while, or sleep on it. Invariably I find that I've overlooked the obvious (such as forgetting to turn up the mixer, not being plugged into the card, etc)
