wheelema
Boner-obo
If you record with a laptop you may have become aware of solid state disk drives such as those used in the MacBook Air, but... ye gods!... the prices!
Well, SansDigital has just come out with a cool little idea that packs two compact flash cards into a 2.5" SATA2 enclosure.
Thus, for $489 (the cost of the enclosure and two highspeed 16GB CompactFlash cards) you can have a 32GB SSD that you could upgrade!
Unlike existing RAID units that employs hard drives for storage space, the CompactSTOR CR2T utilizes pocket-sized lightweight Compact Flash cards as storage memory for data safekeeping. The CR2T supports spanning and RAID 1 (mirroring) by housing up to two Compact Flash cards. Designed with the same size and connectors as a 2.5" SATA hard drive, the CR2T is compatible with the hard drive slot of laptops, industrial PCs (IPC), small form factor computers, and 2.5" hard drive enclosures. By utilizing Compact Flash cards as storage, the CR2T embraces the same benefits as Solid State Disks (SSD), including less power consumption, minimized heat generation, shock prevention, and noiseless operation. The user is able to benefit from the features of a Solid State Disk at a fraction of the cost while using the CR2T.
