If you load the same image on 2 different drives? Not sure why you would want to, but it should just boot to the first drive in the boot order in your bios.
Youll go into your os and the other driver will just look the same as the first...
this is SOOO slow..hope this doesn't end up double posting...
If you load the same image on 2 different partitions? Not sure why you would want to, but it should just boot to the active partition.
Youll go into your os and the other "drive" will just look the same as the first...
