normalize? what to do?
  • Thread starter Thread starter Flash
F
Flash
Hey guy's, I just found an old reel to reel tape of Arlo Guthrie's Alice's restaurant..... so I plugged in my ol' reel to reel and recorded it on my computer. The problem is even with every thing turned up it still sounds really soft. I tried to do a normalize, that did make it louder but now I hear all this hissing going on. Is there a fix for this? I'm using sonar xl. I hope you don't tell me to RTFM. Thanks.....
You can normalize or db boost the signal to get it hot again, and yes you will also boost the tape noise as well. In situations like that I pull out my trusty copy of CoolEdit96 and do noise analysis & removal on the file, leaves it sqeaky clean and quiet with almost no detectable artifacts.
Why wouldn't Sonar have a utility like that? I tried remove silence and then increasing 3db that does help but if I try to do it more than once I get the hiss back. Do you know how much cooledit cost now? The bad part is for as much money that this sonar program cost, you would think it should be able to do what cooledit does....
suggestion
first off. I'm not a pro. I'll probably never be.
however..
Could you play your track in Sonar , load up the paragraphic EQ or whatever EQ you use .. and try to find the frequency that the 'hiss' lives in?
You could then cut that specific frequency range.
Normally hiss being a repetitive high frequency noise, perhaps just cut the really high end off?
Is that a possibility?
If the signal is too low, there's little you can do that will sound any good.
There's an inherent noise floor that's always there. If you record "silence" and play it back cranked, you'll hear it.
If your signal is large enough the space between the noise floor and the average signal level is large. So the noise is fairly negligible.
If your signal is too small, there's little difference between it and the noise floor. To make it audible then, you have to raise the volume -- which raises the volume of everything, of course, by the same amount. Normalizing will just have the effect of making the noise floor louder by the same amount as your signal, and since they're close in levels, you get a noisy result.
Noise removal tactics work OK for very specific noise sources, like a 60-cycle hum, or the pops and scratches of an LP record... but against generalized noise like this, it will not work miracles.
The only solution is to get a decent level into the sound card in the first place. If it's too low there are a couple of possibilities:
(1) The level coming out of the tape recorder is not line level. (Maybe the original recording was made with bad levels in the first place? Then you are screwed.) If this is the case, a preamp might help.
(2) The level off the sound card's line in is set too low. DId you adjust this in the Windows mixer? I'm talking about the recording device's input, not the playback device. If that's not clear, read this article:
http://www.cakewalk.com/Support/Lessons/WindowsMixer.htm
If what you have recorded is inherently noisy becuase of low signal-to-noise ratio, there is simply no magic that can make it good as new. "Acceptable", maybe, depending on how forgiving you can be... I mean, people all listened to noisy Victrolas and record players for a long time and though it was great...
