Noob Rack Gear question.
  • Thread starter Thread starter JG96
JG96
JG96
Active member
So I have a coulpe of old 27 band eqs I would like to use to ring out my bands rehearsal pa. I don't know what the connectors are called but they look just like this.
Does anyone know where I can get some of those connectors? Thanks
Those are crimp type connectors for bare wire. You can get them at an electronic (hobby type) supply store and maybe at Radio Shack. Also in the automotive/trailer section at Walmart they have them sometimes for auto/trailer wiring etc. Don't forget to run a neg and positive for each channel. You might want to check the specs of this thing and see what signal level it is using db/impedance since it is older. This might be it- it has instructions for resistors and connecting the ground to the neg for balanced /unbalanced circuits so you might have to do some homework here...
http://www.jblproservice.com/pdf/Vintage JBL-UREI Electronics/UREI-532.pdf
Forked spade terminal. Any hardware, auto parts or electronics parts store should have them. You can order them online.
Awesome! Thanks! Hardware stores you say? There is a true value about a block from my house so ill have to take a trip over there.
