shagfu
If I am writing a song that is 100bpm, and I have a non-acidized drum loop that says it is 100bpm; can I plop it into a track and duplicate it to fill up several measures and be sure that there aren't any slight overlaps between each copy?
Or does a drum loop need to be beat-matched/acidized/or whatever in order for it to fit exactly within the bounds of a measure? Or should I assume that the length of the clip doesn't change, just the beats within the clip if the drummer is playing a little loose and not robotic.
I ask because if I import a 100bpm acidized loop into a 100bpm song in HomeStudio2002, and toggle between it's acidized/beat-matched state and a normal audio clip...it looks like the waveform changes slightly.
I ask because I might switch from using HS2002 on my PC to recording using Logic on my iBook. And as far as I've been able to find out, Logic doesn't do beat-matching.
