P
psmith66
Having quickly outgrown my Tascam analog 4 Track, I recently began looking into software packages. As a starter I registered n-Tracks, but have also tried the Cakewalk Guitar Tracks demo. The functionality and additional available tracks (n-Tracks) is great - so far (I've been using it for approx one week.
I use a Celeron 533 mgz with 128 mg ram. It has an on-board CMI8738 sound chip (I know it's relatively crap, but I'll upgrade once I get further up the learning curve).
Basically, I run guitars, bass and even vocals through my POD. The POD, as well as my DR-660 drum machine, are input into the Tascam's mixer (stereo or mono depending on the source) and then onward to the computer.
My problem?
Even after maximizing the recording levels, without clipping, there is background noise (more noticable with quieter drum patterns from the DR-660; not very noticable at all for electric guitars). Basically it's a background "hiss/screech/squeal" noise. Is this normal? Is the "baseline" recording level too sensitive? Is it simply the effects of a crappy sound card/chipset?
Also, I can't seem to achieve a sufficiently strong level going straight into the soundcard/chip line in. If I weren't able to boost the signal via POD/mixer, my s/n ratio would obviously suck. Is this normal?
Any help would be greatly appreciated.
My problem?
