shinyst
On location the other day I ran into a troubling scenario with noise, I think it has to do with faulty AC wiring but I'm not sure. Here's my setup :
- Audio Signal Path :
Audio Technica 897 (no battery) connected via a 25 ft XLR cable to a Zoom H6n (48V phantom power).
The Zoom h6n is powered via a 5V USB powersupply.
I have lineout going from the zoom into a Canon 7D, which in turn is powered by a AC adapter (ebay knockoff).
All powersupplies plug into a single elcheapo strip which also has a LED spot light plugged into it.
When I have all of this connected to the wall socket at my place, known well grounded connection, the recorded sound is very clear without any distortion whatsoever.
However, the other day at a location I hooked up the strip to a wall socket and for some reason the sound coming through the AT897 channel was HORRIBLE.. there was a persistent buzz, and pops and clicks all over.
Oddly the sound recorded through the Zoom's own XY mic was perfectly clear!!
I didn't have the chance to plug it into another wall socket to see if that made a difference.
What could be causing this? At first I figured ground loop, but giving all of them were feeding off the same strip that seems unlikely. Could it be floating ground?
How do I solve this at other locations where the AC power isn't well wired? (running all my gear off battery unfortunately isn't an option)
