T
Tomcanning
Hi
I am almost at the point of giving up on recording due to static noise!
I am recording on electro acoustic guitar into maudio fast track USB into my computer.*
There is noise through the headphones even when the guitar is not plugged in. I can post a clip soon if it would help?
I am using pro tools but I get the same noise with audacity (the input volume is also quite low for some reason).
My operating system is as follows but let me know I you need more info about my set up, cables and room it is set up in...
Thank you!*
Tom
Operating System
* *MS Windows 7 Home Premium 64-bit
CPU
* *Intel Core 2 Quad Q8300 *@ 2.50GHz * *35 °C
* *Yorkfield 45nm Technology
RAM
* *4.0GB Single-Channel DDR2 @ 400MHz (6-5-5-17)
Motherboard
* *Packard Bell MCP73PVT-PM (CPU 1) * *28 °C
Graphics
* *Viseo 200Ws (1600x900@59Hz)
* *256MB GeForce 7100 / nForce 630i (Acer Incorporated [ALI])
Hard Drives
* *625GB Western Digital WDC WD64 00AAKS-22A7B SCSI Disk Device (ATA)
Optical Drives
* *ATAPI DVD A *DH16AASH SCSI CdRom Device
* *MagicISO Virtual DVD-ROM0000
Audio
* *Realtek High Definition Audio
Installation Date: 27 December 2009, 14:38
PU
* * * *Intel Core 2 Quad Q8300
* *Type * *DDR2
* *Size * *4096 MBytes
* *Channels # * *Single
* *DRAM Frequency * *400.0 MHz
* *CAS# Latency (CL) * *6 clocks
* *RAS# to CAS# Delay (tRCD) * *5 clocks
* *RAS# Precharge (tRP) * *5 clocks
* *Cycle Time (tRAS) * *17 clocks
* *Bank Cycle Time (tRC) * *24 clocks
* *Command Rate (CR) * *2T
Physical Memory
* *Memory Usage * *40 %
* *Total Physical * *3.74 GB
* *Available Physical * *2.20 GB
* *Total Virtual * *7.99 TB
* *Available Virtual * *7.99 TB
Manufacturer * *Packard Bell
Model * *MCP73PVT-PM
Chipset Vendor * *NVIDIA
Chipset Model * *GeForce 7100
Chipset Revision * *A2
Southbridge Vendor * *NVIDIA
Southbridge Model * *nForce 630i
Southbridge Revision * *A2
System Temperature * *27 °C
* *Manufacturer * *Western Digital
* *Business Unit/Brand * *Desktop/WD Caviar®
* *RPM/Buffer Size or Attribute * *5400 RPM with 2 MB cache
* *Interface * *ATA
* *Capacity * *625GB
* *Real size * *640,135,028,736 bytes
* * * *S.M.A.R.T
* * * * * *S.M.A.R.T not supported
* * * *Partition 0
* * * * * *Partition ID * *Disk #0, Partition #0
* * * * * *Size * *15.0 GB
* * * *Partition 1
* * * * * *Partition ID * *Disk #0, Partition #1
* * * * * *Size * *100 MB
* * * *Partition 2
* * * * * *Partition ID * *Disk #0, Partition #2
* * * * * *Disk Letter * *C:
* * * * * *File System * *NTFS
* * * * * *Volume Serial Number * *CEFF0A98
* * * * * *Size * *290GB
* * * * * *Used Space * *142GB (49%)
* * * * * *Free Space * *149GB (51%)
* * * *Partition 3
* * * * * *Partition ID * *Disk #0, Partition #3
* * * * * *Disk Letter * *D:
* * * * * *Volume Serial Number * *840084F8
* * * * * *Size * *291GB
* * * * * *Used Space * *6.35GB (3%)
* * * * * *Free Space * *284GB (97%)
Sound Cards
* *NVIDIA High Definition Audio
* *M-Audio FastTrack
Playback Devices
* *Line (2- M-Audio FastTrack)
* *Speakers (Realtek High Definition Audio) * *(default)
* *Realtek Digital Output (Realtek High Definition Audio)
Recording Devices
* *Line (2- M-Audio FastTrack) * *(default)
* *Stereo Mix (Realtek High Definition Audio)
Speaker Configuration
Thank you!*
Tom
Operating System
CPU
RAM
Motherboard
Graphics
Hard Drives
Optical Drives
Audio
PU
* *Type * *DDR2
Physical Memory
* *Interface * *ATA
* * * *S.M.A.R.T
* * * *Partition 0
* * * *Partition 1
* * * *Partition 2
* * * *Partition 3
Sound Cards
Playback Devices
Recording Devices
