no playback with Delta 1010LT in midi
  • Thread starter Thread starter peteuk90
P
peteuk90
Hi there, sorry if I appear thick.. just learning about MIDI!! I have a delta 1010LT sound card which is great. Just starting recording bass,guitar etc. The drummer has got an electronic drum kit which we were advised to record in midi then convert each track etc. When I plug the midi cables in and audio I hear it and it is creating notes on the screen to say it is recording a pad (snare) I have set the driver to delta card but no play back at all. It's all there except sound.
I run it on MAGIX Deluxe 2005 software.
Helpppp!!
Recording drums in MIDI only makes sense if you have a good drum softsynth and/or if you want to fix timing.
The Midi Mapping may not be set up correctly for the kit.
Uh, you DO know that the Delta does NOT have a MIDI synth built into it???
You're going to have to route the MIDI through a synth (software or hardware) that'll make sounds when it recieves a MIDI note!
