Dr. Varney
Pimp
I've gotten over the basic hook-up issues I was having and made some successful recording tests into both Steinberg Cubase and Cakewalk Sonar LE.
Now I want to move on with Sonar and begin learning the basics. I've started with reading Help and loading up 'Tutorial 1'. Now I'm stuck!
The problem is that although I have managed to successfully record (and play back the audio) in Sonar, I cannot get any sound from Tut~1.
This does not make any sense; especially as I was starting to gain a little confidence in setting up Sonar, in accordance with my hardware. Now I feel I am back to sqaure one and feeling frustrated again... One step forward and two back!
Relevant hardware consists of the E=MU 0404 PCI soundcard, which uses DSP Patchmix.
Now, when I came to set up for recording, I didn't really need to do very much. I notice that the inputs and outputs for each track on my test piece read: Stereo E-MU PCI CARD and E-MU ASIO ASIO31/32. This is obviously why it works.
Now on Tut~1, the output reads: "1-E-DSP MIDI Port (AC00)" and the only other options consist of "New Drum Map" and "Drum Map Manager"?!
(Quite what drums have to do with selecting an output to a soundcard, I really can't fathom!)
Input reads: "Omni" and the other options consists of: "None" (that's useful!) and then a sub-menu of "E-DSP MIDI Ports" from "MIDI Omni" and then: "Ch 1-16". The only other options available are "Manage Presets" and "Presets", which is greyed out.
Now if I start with a new project, I find the I/O of the empty tracks appear already set up correctly. I don't understand why Tutorial 1 isn't the same.
So can anyone tell me- what I am missing here?
Thanks in advance
Dr. V
Thanks in advance
Dr. V
