G
goodbyebluesky
Seeing as I have none of the following, what are the opinions here on what I should purchase first as the next logical choice of gear aquisition.......?
This is the extent of my setup right now:
So whats everyone's opinion?
- Graphic EQ- which I have no experience with but I think could clean up my guitars. I get some boominess and loose-sounding bass frequencies while even recording direct and a good eq should help with that right?
- Compressor- I'm a bit intimidated since I'm not educated on how to use one, but I know I need it. Especially if I end up recording bass rather than go direct.
- Tube Preamp- I won't be recording vocals for a while so its not critical yet, but I know I need one and would like to get one versatile enough to track everything through it and really warm it up.
- Reverb- I put this last since its mostly a post-recording thing and I won't be turning out finished stuff for a while. I'll probably get blasted for this but I can also use the reverb/delay in my POD in a pinch. Kind of a lo-fi alternative used subtly.
- Line 6 POD Pro for recording guitars direct
- 2x12 cab, can be mic'ed in the future when I upgrade mics
- Samson Servo amps, one for guitar rig, and one for monitors in the future
- Tascam DP-01
