B
bluesboy2003
Hello. I’m new to the HR.com BBS but wanted to try posting now, because I’m in a bit of a confused mess at this point
I am just looking to do some one-man band type amateur, self-amusing projects. The objective here is fun, not professionalism, but I am someone who really appreciates quality, and so I am willing to pay for a few good products that will last me long enough to see me into the next tax-bracket, when I can afford the next level of dedication and quality. I’m not seeking to overthrow George Martin as the master producer, I’d just like to be able to end up with a few tunes that I could hand to a friend and have him or her listen and say, “That sounded good.”
I currently own a PC has a 1GHz Athlon and 512MB of PC133 RAM under the hood, with two IDE drives, one 40 GB and the other 30 GB, so I’m hoping this would be okay (if not we can discuss building a new one, but I’d like to get by with what I can for now). Unfortunately, I have an embarrassingly sad soundcard as far as recording goes: a lowly Creative Soundblaster PCI128. I've managed to get two tunes out of it, but it's time for something more respectable. The only thing is I don't know exactly what that is.
I create my backing tracks on my Roland XP-60 and then record them on to the PC, and then lay guitar down over them. The guitar is wired to my Tech 21 PSA-1 that I run into my soundcard. Ideally what I'd like is an interface that would allow me to have both my synth-workstation and my guitar pre-amp plugged in, but at the bare minimum, I would need at least two 1/4" inputs for recording in stereo. I don’t really need to record both at the same time; one instrument at a time is fine for me.
I will be doing my recording in my apartment, which means noise is a no-no, and hence, I plan on recording direct. The XP-60 features only ¼” outputs, but the PSA-1 has both ¼” outs and XLR outs. An option for being able to attach mics might be nice for the future, but again, at this point, it’s not really useable. I think I can do without a physical mixing interface; point and click with the mouse will do just fine. I really haven’t a clue what differences lie between the PCI card interfaces and the USB interfaces other than where they are attached to the PC. I do not have a Firewire card on my PC so I will not be able to use those type interfaces.
Since I am going to be recording in an apartment, I would like to be able to listen to the recordings and maybe do preliminary mix-down using studio-quality, closed headphones. Could you recommend a pair? Are there any good soundcards with interfaces that meet the necessary ohm-ratings of good headphones, or will I need a separate headphone amp, and if I will need a separate amp, do you have any suggestions?
I am unsure at this point if I should invest in monitors. I am aware that it is a bad idea to mix using headphones, but again, these aren’t intended to be professional-level recordings. If you guys say they are critical, though, I’m willing to listen to suggestions for monitors that are economical, yet don’t cut corners that shouldn’t be cut. I would assume I need powered monitors, but I’m unsure.
I also use Quartz Audiomaster as my recording software. It’s been fine for me to use, but I'm not sure how compatible it will be with a new (real) recording interface. If new software is needed, what should I be looking to get, and how much would I be likely to need to spend? I have seen a few mentions of n-Track here and there. Is that fairly intuitive and useful? I can’t see that something like Cakewalk Sonar would be worthwhile to me; it seems I wouldn’t be capable of utilizing sophisticated features.
I would really like to spend as well below $1,000 in total as possible, if possible. Again, if the computer isn’t up to par, I’d be open to discussing upgrading, but the longer I can hold out with what I’ve got, the greater the return on when I finally do buy a new box.
Thank you so much for your help and your time. I have really been trying to do my homework on this, but the more I read, the more I realize I don’t know, and the more I wonder how much time and money I could lose trying to figure it all out by guesswork. I really appreciate this forum being here and the members being so active. From what I’ve read through on here, you guys have an amazing wealth of useful information.
Thanks again,
Chris
Thanks again,
Chris
