T
trey
I've run through the audio set up process for Cubase, apparently without problems. The simulation test says everything is OK.
My PC is 350mhz, 64mb and runs Cakewalk fine.
My problem is a delay in hearing back audio. At first I thought there was a delay effect switched on somewhere, because I hear the original signal in low volume, and then it repeats louder. It's a great delay effect but annoying as hell
So this must be a buffering/latency issue? But how do I put it right? The ASIO simulation test says there isn't a problem.
It's those new programme set-up blues..............
