G
girlthatdrums
alright, i'm just getting really frustrated now, so hopefully someone can help. let me explain by saying i talk the talk, but don't walk the walk. i know enough to get around in a live setting, but really I'm a drummer-once-pianist wishing i knew how to do more computer-music related things.
i've got the following semi-set-up:
mackie 1402
m-audio delta 44
yorkville ap4040
dod dimension 3
reason 2.0/windows xp
pc midi-flyer
baldwin dg-100
yamaha club series monitors and speakers
so the problems I'm having are:
1) do i need a pre-amp from the mackie to the delta 44? i was hoping i could just run out of the monitor line outs on the mixer into line 1&2 of the delta 44. it doesn't seem to find it though.
2) no matter what i try, the pc flyer will not work with windows xp. i can run the piano through the line-outs i have into the mixer and then out, but it would be so much more convenient to get the midi up and running.
3) the outs on the delta 44 don't seem to function no matter what i try. can someone explain the correct set-up on this if i wanted to bypass my audiocard (complete crap)?
4) is there a simple wav recording function in reason, or should i just get something simpler for that and create samples outside of reason? suggestions?
Basically, what I'm trying to do is intergrate my live sound system (the mackie 1402/dimension 3/ap4040) with my computer system (xp/delta 44/baldwin dg100/midi pc-flyer) so i can use the live sound system, record rehearsals, control the digital piano through the live sound system and playback computer compositions.
If this were put in a big box in front of you, how would you do it? Do i need something integral I'm missing?
Thanks!
mackie 1402
m-audio delta 44
yorkville ap4040
dod dimension 3
pc midi-flyer
baldwin dg-100
Thanks!
